Hallo, ich bekomme aPager für iOS nicht zum laufen.
SendMessageApagerIOS - Fehler beim Push-Versand: Communication exception: java.net.ConnectException: Connection refused: connect
aktuelle Version FE
Java 6
Win XP
Auszug Log:
02.05.2013 - 09:13:22.002 ERROR SendMessageApagerIOS - Fehler beim Push-Versand: Communication exception: java.net.ConnectException: Connection refused: connect
javapns.communication.exceptions.CommunicationExce ption: Communication exception: java.net.ConnectException: Connection refused: connect
at javapns.communication.ConnectionToAppleServer.getS SLSocket(ConnectionToAppleServer.java:158) ~[firEmergency.jar:na]
at javapns.notification.PushNotificationManager.initi alizeConnection(PushNotificationManager.java:106) ~[firEmergency.jar:na]
at javapns.notification.transmission.NotificationThre ad.runList(NotificationThread.java:215) ~[firEmergency.jar:na]
at javapns.notification.transmission.NotificationThre ad.run(NotificationThread.java:199) ~[firEmergency.jar:na]
at java.lang.Thread.run(Unknown Source) [na:1.6.0_34]
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method) ~[na:1.6.0_34]
at java.net.PlainSocketImpl.doConnect(Unknown Source) ~[na:1.6.0_34]
at java.net.PlainSocketImpl.connectToAddress(Unknown Source) ~[na:1.6.0_34]
at java.net.PlainSocketImpl.connect(Unknown Source) ~[na:1.6.0_34]
at java.net.SocksSocketImpl.connect(Unknown Source) ~[na:1.6.0_34]
at java.net.Socket.connect(Unknown Source) ~[na:1.6.0_34]
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.connect (Unknown Source) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.SSLSocketImpl.<init>( Unknown Source) ~[na:1.6]
at com.sun.net.ssl.internal.ssl.SSLSocketFactoryImpl. createSocket(Unknown Source) ~[na:1.6]
at javapns.communication.ConnectionToAppleServer.getS SLSocket(ConnectionToAppleServer.java:155) ~[firEmergency.jar:na]
... 4 common frames omitted
Hatt jemand einen Tip ?
Gruß Frank
Prowl und aPager (Android ) gehen durch.
Sind bei aPager (iOS) andere Freigaben notwendig?
Ich habe das selbe Problem, welche Ports müssen denn geöffnet sein?
Ebenso die Frage für die emailüberwachung... Port933 und?
Vielen dank
Also ... laut Apple :
"Push providers, iOS devices, and Mac computers are often behind firewalls. To send notifications, you will need to have TCP port 2195 open. To reach the feedback service, you will need to have TCP port 2196 open. Devices and computers connecting to the push service over Wi-Fi will need to have TCP port 5223 open."
Sprich ... der Port 2195 muss von eurem FE Rechner aus offen sein ... damit ihr da raus kommt ....
Bei der Anzeige der Geokoordinaten kommt es häufig vor, dass diese so aussehen:
50.951592
9.139587999999999999999
Könnte man es so ändern (kürzen oder runden), dass nur max. 6 Stellen nach dem Punkt angezeigt werden? Irgendwie sieht das nämlich immer unschön aus. In FirEmergency selber werden die Koordinaten korrekt angezeigt und nicht wie oben beschrieben.
Hallo zusammen ,
Ein Kamerad von mir hat sich A Pager gekauf und auf dem I Pad installiert Meldungen kommen auch an.
Nun wollte er es dann aufs I Phone installieren hat auch geklappt nur wenn er da dann auf Mail senden klickt um die Nr zu senden geht die app zu.
Auf I Pad und Handy runter geschmissen und neu drauf getan aber geht immer noch nicht
Könnte man im Feld "Ort" noch zusätzlich eine Zeile einbauen, in der das Gebäude angezeigt wird? Wenn kein Gebäude gefunden wurde, die leere Zeile unsichtbar lassen.
Hallo und zuerst vielen dank an die Entwicklung für das iOs apager.
Wir stellen das Phänomen fest das die Meldungen langsamer sind als prowl und android. Weiter treffen mehrere Meldungen in FE zeitgleich ein aber dann gehen sie scheibchenweise raus.
Hat sonst noch einer so ein Phänomen?
